I had already tried this file but it didn't workno display need try new bios . not repair .
here :
didn't work mean the bios has same result like old file ?I had already tried this file but it didn't work
With the original file, the display is random.didn't work mean the bios has same result like old file ?
This indicates that the BIOS file you sent is corrupted. It didn't work.if the clear me file has same result like old file then you should check hardware
but your old file have same problem as you said above !This indicates that the BIOS file you sent is corrupted. It didn't work.
Blaise , Vahab Hemmati , user46647 , mkadalim , Oxifixtech , Asghar ali
